Globally enables ping protection for static routes added with ping protection for IPv4 and IPv6.
| ipv4 | Specifies IPv4 (default). |
| ipv6 | Specifies IPv6. |
| protection | Enables route protection. |
| ping | Globally enables ping protection for static routes added with ping protection (default is enabled). |
Enabled is the default. If not specified, IPv4 is the default.
The following example enables ping protection for static routes added with ping protection for IPv4:
# enable iproute ipv4 protection ping
This command was first available in ExtremeXOS 22.1.
This command is available on all platforms with any license level as described in the Switch Engine v33.1.1 Licensing Guide document.
